Home > In Car Electronics (L322) > 2003 Vogue Stereo problem....
Pedrochellie
United Kingdom 2003 Range Rover Vogue 4.4 V8 Epsom Green
My stereo developed a problem today.........listening to the radio it just suddenly switched off - just the sound, the display works fine. I turned it off and on again and all ok for about a minute then the sound went off again. It keeps doing this now and also does it on CD........
Anyone have any ideas where to start with this problem, could it be the BM54?? Confused
Thanks FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #123479 24th May 2012 6:16pm
mjdronfield
If it is the BM54, the upgrade from Baris may fix the issue as well.........give him a call ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #123496 24th May 2012 7:04pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Its the blue plug on top of the right hand unit - it will be corroded. Mine did exactly the same so I took it off cleaned using degreaser on the plug and anp pins then a light film of WD40 and put it back together - now works fine Wink
Post #123508 24th May 2012 9:15pm
Pedrochellie
Thanks Guys, I have contacted Baris and will be doing the upgrade so hopefully that will be the end of problem, although I will check the plug mercs, thanks for that Thumbs Up FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #123517 24th May 2012 10:03pm
Pedrochellie
Quick update - the problem has disappeared...........all working as it should Laughing
Seems my FFRR likes playing these tricks on me........ FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #124058 28th May 2012 10:12pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I had a similar problem once - all exactly the same - and then the Sat-Nav crashed, rebooted and all was lovely again.
Post #124097 29th May 2012 9:18am
I have an issue where the Radio cannot find any station as if the arial is disconnected does anybody have experience of this issue?
Post #124149 29th May 2012 2:49pm
could you have actually knocked an aerial connection gary.. ... - .- -.
Post #124156 29th May 2012 3:21pm
Nor mean but previous owner may have. I just wondered if anybody had ever had similar symptoms?
Gary
Post #124157 29th May 2012 3:23pm
SteveMFr
Site Sponsor
Very rarely the antenna amps go on the fritz too.
Looked for a quick diagram for the various antenna amps online - couldn't find one. If it is the FM antenna amp that's bad, the main amp (where diversity signals come together) is above and to the right (fwd) of the nav computer.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #124171 29th May 2012 4:13pm
OK will have a look. It odd that it simply does not locate any stations?
Post #124173 29th May 2012 4:17pm
you've probably done it but what about a battery disconnection? ... - .- -.
Post #124174 29th May 2012 4:19pm
done it.
Post #124177 29th May 2012 4:22pm
Pedrochellie
Oh boy - here we go again!!
Today my stereo decided to keep playing the radio station it was on but the display of all stations, CD and tape has disappeared!! You can't change stations or get the CD/Tape to come up on screen - just blackness! (I have the MK4 DVD nav unit upgrade and the screen is set on splitscreen and Nav unit and nav screen dispaly works fine)...........you have to turn the stereo off and on again and the functions are there but disappear again soon after.
Does the BM54 control the FM, tape and CD functions or is there another 'box' that does this. I'm going to send the BM54 to Baris soon but wondered if it's that at fault or not?
Thanks All FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #125191 6th Jun 2012 6:22pm
