Home > Technical (L322) > wows after removing door mirror
daveo
hi has any one take off a mirror with chromatic glass, main plug goes into the switch unit but i cant find where the flat 4 pin plug goes from the chromatic glass , the chromatic plug from the mirror is the same as the flat ibus plug...all so after putting back the trim the message door open keeps popping up but never see the switch for that.. V8 facelift Range Rover Autobiography 22" wheels.
Post #123765 26th May 2012 6:18pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Fck knows. Sorry my reply is no help. MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #123793 26th May 2012 11:16pm
Dave
I'm sure that the plugs are behing the door card, round the window switch. Been a while since I had mine off. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #123800 27th May 2012 1:12am
daveo
i will have to whip off the door card again, need to look for the door switch as well,it must of fell behind the door foil.. V8 facelift Range Rover Autobiography 22" wheels.
Post #123802 27th May 2012 7:47am
Which mirror Dave? Driver or pass?
If its drivers please be carefull to double check your plugs as the height button and chromatic plugs are the same size and shape... If ya plug them the wrong way round you'll make your mirror glasses go blue and screw up your eas...
Craig Thumbs Up
Post #123804 27th May 2012 9:25am
daveo
Well i have had 2 new mirrors fitted curtsy of the insurance company, and it started when i noticed the access button was not working, they took the driver door card of and i pointed out that they have plugged the chromatic
wire from the mirror into the switch panel, i got them to change it with the correct wire but then there was no other plugs this side of the door foil for the chromatic, when they put it back to gather the access switch was working but would not lower as it now says door open on the dash.so it thinks the door is open.. V8 facelift Range Rover Autobiography 22" wheels.
Post #123828 27th May 2012 2:24pm
There is three plugs in a plastic holder mounted vertically tweeter speaker wire, anti trap for window and the chromatic/puddle lamp plug so it must be around there somewhere... But, if they plugged the wrong plug in you may have problems unfortunately!
Had the same thing happen to a customers car who had the drivers door painted and the bodyshop they used plugged the two plugs in the wrong way around and it Censored both mirror glasses (they turned blue)
Craig Rolling Eyes
Post #123871 27th May 2012 11:08pm
daveo
well they are aware they put the wrong plug in the door switch module, they put the chromatic plug instead of the ibus plug, funny i thought they would different plugs to stop something like that happening, funny i did notice two other plugs not connected. i am hoping one of the other is the door switch.
dave V8 facelift Range Rover Autobiography 22" wheels.
Post #123874 27th May 2012 11:35pm
Sounds like a good job done Dave Whistle
Not Banging Head
Craig Thumbs Up
Post #123901 28th May 2012 9:01am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
did you fit the newer style mirrors? if so did you have any trouble with getting all the systems to work e.g. dimming, folding etc....
Matt
Post #124121 29th May 2012 11:21am
ebajema
Seems like JLR/BMW are not familiar with the original Murphy's law : If a part can be mounted two ways, a correct and incorrect way, then there will always be someone installing the part incorrectly at some point in time.
On an aircraft that can be quite problematic and even on an car it can be cause serious problems sometimes. MY 2010 5.0 SC Galway green and sand interior!!
Post #124123 29th May 2012 11:32am
