![]() | Home > Maintenance & Mods (L322) > Rust bubbles - Land Rover Warranty? |
| Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964
There is one really easy way to find out....
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
If the paint and metal is all original I can't see how they won't cover it. Might be time to find another LR dealer |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
The LR paint warranty is only enforceable if you can prove it has only ever been to a LR Dealer for servicing and body check. Discovery 4 HSE
| JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889
had my 2006 wheel arch lips sorted last year, so it is possible to successfully make a claim. Get it to the dealers ASAP. |
| EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181
I had the same on a 2008MY VSE and they replaced the tailgate all under warranty. Best of luck... '96 Volkswagen Polo 1.4CL - SOLD
| Stephen.Gazard Member Since: 10 Apr 2012 Location: Bristol Posts: 192
Thanks .....
| martincfreeman Member Since: 15 Mar 2011 Location: Flatlands of Lincolnshire (but the Kerbs are pretty high!) Posts: 30 |
Hi,
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8789
^^^^^ same with gs cov.
| swirl80 Member Since: 11 Dec 2011 Location: Northumberland Posts: 46
just to add to this, I've had a few areas of the body work on my MY2007 TDV8 which started bubbling over the last 7mths, Stratstone Newcastle have sorted with no hesitation..... |
| GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836
I've just bought a MY07 Vogue SE - totally loving it!
Seems to depend on the dealer, be as pushy as you can, and get a friendly dealer and you should be ok.
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6838
I discovered a small blister on the top tailgate, so took it into my local dealer. The guy from the service dept came out and took a brief look, agreed that it "looked" like rust from the inside, so he's told me to take it to their approved bodyshop in Glasgow for "further investigation". I'm expecting to have to fight for it to be repaired under warranty! |
| IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502
The side strips on my tailgate are showing signs of corrosion and bubbling, mentioned it to the dealer on Tuesday when the car went in with alarm problems so will report the outcome.
Both strips on side of glass replaced, dealer had them in stock so suggests a common problem.
| All times are GMT |
