![]() | Home > Technical (L322) > Exploding Suspension whilst driving - REPAIR UPDATE PICTURES |
Very simple job, remove the clip and twist it out. Then remove the airline and replace... Easier than the old P38...
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6430 ![]() ![]() |
You may need/want to do both rears so you won't be lopsided or have calibration issues. I would. .
RANGEROVER Member Since: 25 May 2010 Location: EAST OF ENGLAND Posts: 48 ![]() ![]() ![]() |
I will hopefully get a bag next week, My plan is to put a bag on and try to clear the faults and see what happens??
Firstly many thanks to John (47p2) & Craig for advice received via PM's.
The point where the sensor is broken is a common fault caused by two different types of metal corroding and the joint becomes seized
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 326 ![]() ![]() ![]() |
Hallo Fans, yesterday I had the same problem like RANGEROVER, at my 2002er it was in the front left, with a good and loud PIFFFF says directly at my home the spring to me: GOODBY..........., just orderd at island4x4 a pair of new for both sides..., will inform you! And also I will order the airbags for the rear side!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35852 ![]() ![]() |
thanks for the pics RANGE ROVER... |
Great pictures - what a mess! Really helpful As I see this coming my way soon |
I suggest all pre 2005 owners go and have a check..... |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
I just replaced all four on my car. The rear ones have to be completely deflated to get them out. I ended up drilling a hole in mine to get all the air out, then they came off easily. It's important to have a pair of pliers with a long tip to get the clip on top off. ----------
