![]() | Home > Technical (L322) > PDC - Ahhhhh more problems |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 ![]() ![]() ![]() |
Has anyone had problems with their Park Distance Control going wrong.
Mine some times give up and then come back after a re-boot seems to be if you select reverse too soon after starting the engine. Once happened after heavy rain as well but al is OK now. 2008 MY Supercharged
Axle - what do you mean by a reboot? is this something i can do or is it a factory reboot |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6377 ![]() ![]() ![]() |
When a sensor goes wrong the system gives an auditory beep to alert the driver. Simple way to check is to switch ignition on, put sensors on and get someone to put a hand in front of each sensor at a time, then you'll know which one is duff.
Vogue Owner by re-boot I just mean switch off to half an hour then re start, but I still find selecting reverce to soon will give it a dose of the sullks . 2008 MY Supercharged
Axle - yes you are very correct - putting it into reverse as soon as you start up has caused quite a few issues - one in particular was the suspension problem i had on Wednesday where the ride height was set on access mode.
