Home > Technical (L322) > Exterior Mirror Dip when reversing
Both my mirrors dip when reverse selected
Post #123657 25th May 2012 6:20pm
daveo
i thought it was only the passenger side mirror that dips, well it is on mine, any one else have both mirrors dip with reverse V8 facelift Range Rover Autobiography 22" wheels.
Post #123678 25th May 2012 9:50pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
2010 MY - both dip - hence I had it turned OFF, bloody pointless. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #123679 25th May 2012 9:57pm
fraserl322
Australia
mjdronfield wrote:
The mirror will only dip if the car has memory seats fitted.
I assume it was working before, as oppose to it never having worked ?
So if you have an HSE or something without memory seats the function won't be there.
Sorry if you've had your car for 5 years and know it inside out - just trying to cover all bases. Smile
Mark
Thanks Mark, it has the memory seats, and the driver's mirror moves to suit memory settings, but the passenger mirror never moves except manually. switch in either position.
Maybe potentiometer faulty...need to get some sort of diagnostic device!
Cheers,
Fraser
Post #123689 26th May 2012 12:11am
daveo
so if you have memory seats as i have, they are both meant to dip as only the passengers side dips on my car,i thought only one was meant to...
[this is when reversing], normally they both do dip. V8 facelift Range Rover Autobiography 22" wheels.
Post #123694 26th May 2012 6:29am
mjdronfield
Only the passenger side dips on the earlier cars.......or maybe even until recently......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #123711 26th May 2012 8:03am
daveo
well mine work ok then Very Happy V8 facelift Range Rover Autobiography 22" wheels.
Post #123758 26th May 2012 4:14pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
My 2000 P38 dips both mirrors in reverse.
The 2005 only dips the passenger side, and only if the mirror select switch is in the "driver's side" position.
Backing out of my garage at night, the mirrors might as well not even be there.
There's no streetlights where I live, the driveway is black asphalt, and the bit of grass is dark.
Add in the limo-black windows, and I can't see anything in the side mirrors.
I roll out of the garage straight back, when the bumper clears the door plus 3 feet, cut the wheel hard right, and I'll end up in the street.
I was going to put rope light along the edge of the driveway where the pavement meets the grass, triggered on garage exit, but I figured the snowplow knuckleheads would just destroy it when they plow the driveway. Jim
2000 NAS HSE
2005 NAS HSE
Post #124302 29th May 2012 11:21pm
