![]() | Home > Maintenance & Mods (L322) > Fitting Overfinch rear roof spoiler for my 07 S/C |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
Should be a doddle.
cuda Member Since: 21 Mar 2012 Location: london Posts: 24 ![]() |
ok thanks so that doesn't interfere with the camera? 07 S/C in Java with Ebony |
Ahhhh. You'll have to check with the seller about the camera - I would assume that if the spoiler has been designed properly, it will have a mounting bracket / holes for the camera and you'd just swap it over from your current spoiler to the new one.
i asked the seller whether it interferes with the camera and he says:
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
A quick search revealed some useful photographs of rear spoiler removal and camera changing http://www.fullfatrr.com/forum/topic4621.html (but I don't know where the plug to the camera wires is). |
i have pics of the spoiler but no idea how to post on here as there's no browse button like on p'heads...!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35762 ![]() ![]() |
have a look in site announcements for picture posting how to.. ... - .- -.
jeez thats alot of admin just to post a pic... 07 S/C in Java with Ebony |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6818 ![]() ![]() ![]() |
Spend time doing admin, or spend money on a spoiler you can't use! Tough call! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
If its a proper Overfinch spoiler then you have to remove your 3rd brake light and fit the spoiler in the same holes after fitting the brake light back into the same size and shape hole/recess in the spoiler... So a kind of piggy back affair if that makes sense... You'll need to remove the inner top trim panel that covers the wiper motor to unplug/replug all the wiring for the brake light and camera etc... Craig ![]() |
Wee-socks Member Since: 20 Feb 2012 Location: Glasgow Posts: 2 ![]() ![]() ![]() |
Hi I am new on here and noticed your post!!! I fitted one to my RR last week and it is straight forward if you need any info or pics pm me..... |
well just spent 15 mins following the guide and trying to upload an image to my new gallery and it keeps on showing up as empty so not gonna waste any more time on that unless a moderator can pm me how... 07 S/C in Java with Ebony |
Tried again - lets hope this works...
