Home > Technical (L322) > car wont turn over!
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Update - Frequency of the 'problem' on my one increased.
Identified as the starter motor clutch. New starter fitted and problem solved.
Post #124617 1st Jun 2012 8:35am
That would be my best bet too - something at the starter motor .
Post #124627 1st Jun 2012 9:07am
ebajema
Also check the battery lead clamps on the battery. Check if they are loose and check for corrosion on the clamps/poles. Clean the inside of the clamps (fine sandpaper and cloth) and the outside of the poles and put a thin layer of vaseline on it (to prevent future corrosion). Check all the earth connections, especially the bigger ones, take them off, clean them and put them back with some contact cleaner or the likes to prevent corrosion. A little resistance with 12 Volts can cause a big voltage drop. MY 2010 5.0 SC Galway green and sand interior!!
Post #124650 1st Jun 2012 11:49am
