![]() | Home > Technical (L322) > Urgent Help Needed Thanks! SOLVED! |
Pedrochellie Member Since: 23 Feb 2012 Location: Surrey Posts: 82 ![]() ![]() ![]() |
UPDATE 2 - ok i think its the heated steering wheel button control - three pins - green, yellow and blue - I have clipped the plastic side bit off so it will fit the new wheel connector and the green, blue & yellow wires follow through from both connectors (male and female) so that must be right.............! FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Swap the small black box in the bottom of the wheel over as the later 2009> box has the wrong connector...
Thanks Craig - in the end I just snipped off the tab that was in the way and connected it up after checking the wire colours matched through!
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
How long did this take to do and is it something that someone with limited mechanical ability (and confidence) could attempt? African Bush Junkie ... in London!
dave.s Member Since: 01 Nov 2011 Location: Isle of Wight Posts: 127 ![]() ![]() ![]() |
very easy to do, have a look on powerful uk web site video shows how to.
Hi DeRanged,
