![]() | Home > General > Warning triangle? |
Should be one in the rear off side pocket of the boot |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8771 ![]() ![]() ![]() |
Nope, |
*OPTIONAL* Land Rover Addict
Great! Need to buy one for france trip. There is nothing that can't be fixed with a hammer๐๐
Cheap enough on ebay |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8105 ![]() ![]() ![]() |
Not ideal when stored in the proper place unless your boot is empty !
Deep Down Member Since: 06 Apr 2011 Location: Deux Sevres Posts: 104 ![]() ![]() ![]() |
Don't forget your fluorescent jacket, it needs to be stored in your front door pocket as you're supposed to put it on before you get out of the car.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35821 ![]() ![]() |
one shiney jacket for each passenger as well i believe.. ... - .- -.
Cheers guys, have pretty much all of that stuff, top tip, put the hi vis on the back of the drivers seat, police can see it there and when they are doing the roadside stop and check routine may just convince them to let you past.
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
alcohol testers?
This is all about France so no they just eat the horse |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
Yes, its continental europe and the cheese eating surrender monkies that need you to have all of this stuff, in the uk you can carry nothing and it will be fine, more or less. There is nothing that can't be fixed with a hammer๐๐
cleughy Member Since: 08 Mar 2012 Location: West Kirby Posts: 361 ![]() ![]() ![]() |
it reminds you a bit of the top gear item when JC tested the jag estate and had everything in the boot even a member of the SAS. |
