Home > Technical (L322) > 1010-2012 LCM lighting control module 2004-2010 upgrade
klf400
hi guys this has been talked about before as it may be the answer to fitting the rear 2010 on led lights and the headlight clusters , would be great if thats all it was , has anyone got any pictures of the lcm ? and would it be backwards compatible ? i have been looking through a load of 2010 ecu,s but most of them its difficult identify what they are 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #125709 11th Jun 2012 7:18pm
daveo
what do you want,a picture of the LCM,,, V8 facelift Range Rover Autobiography 22" wheels.
Post #125742 11th Jun 2012 9:35pm
klf400
yes if you have one Smile 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #125759 12th Jun 2012 7:09am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
If it is anything like the LCMs on the BMWs then you might have to get it re-flashed at the dealer to work with your car, used LCMs could not be re-flashed as they stored mileage info etc. Maybe the equipment is different now, but with the L322 having so much in common with the BMWs I would check this with a dealer before parting with any money for the unit. I think a new LCM for my old BMW E46 Cabrio was about £350 from the dealers so it makes sense to use the resistors instead. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #125767 12th Jun 2012 8:32am
if it were possible or practical then the professional conversion guys [craig] would have done this rather than the resisters and circuitry route.. ... - .- -.
Post #125768 12th Jun 2012 8:42am
klf400
all these are valid points , as i said this has been talked about but has anyone fully investigated the possibility so it can be disregarded Smile 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #125848 12th Jun 2012 6:19pm
