![]() | Home > In Car Electronics (L322) > GPS has line through it |
take the disc out and reload, or do a battery disconnection....might help. ... - .- -.
Elena Member Since: 10 May 2012 Location: Coventry Posts: 42 ![]() ![]() ![]() |
Hi Stan
the battery disconnection procedure is in the wiki, here's the link http://www.fullfatrr.com/wiki/Battery_dis-connection_procedure ... - .- -.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3926 ![]() ![]() ![]() |
TMC might just be you are out of range of a suitable Radio station obviously for the GPS bit to function you need to have sight of the sky. Both these problems could be caused simply by location I.e. in a garage. Geoff |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Re-tune the tmc station should sort out the TMC issue, my car regularly selects Heart FM for the tmc service, probably because Heart FM are abusing the TMC system. |
Okay, TMC now sorted but after battery disconnection etc still have a line through the GPS, any other ideas please.
all i can think of is to check and recheck all the connections relating to the nav unit. ... - .- -.
cheers Stan, now the rain has stopped I will have a look |
All connections look fine, as far as I can see. The GPS was definitely working before the battery was changed. The manual does state that a battery disconnection can cause this fault but it doesn't tell you what to do about it. |
