Home > Technical (L322) > Third dead Alternator
bjs
Hi all,
Well bang it goes again, this is the third one and this time the failure is quicker than before...!!! (l322 4.4 v8 2002)
There is obviously an underlining problem and I have read a few thoughts,
1. Battery has faulty cell - buying new battery just working out which one..
2. Faulty earth somewhere causing alternator to fail ???
3. Unlikely but third alternator failed !!!
So my question is do you have any knowledge of this and are able to provide pointers as its getting a bit ridiculous.. ?
I have ordered another alternator which is a genuine Landrover unit... in preparation but don't want to fit until problem sorted, as they are not cheap....
HELP ????? Big Cry
Barry
Post #125787 12th Jun 2012 11:04am
steviebabes
England 2003 Range Rover HSE 4.4 V8 Epsom Green
I am as hopeless with electrics as I am with mechanicals. But until someone learned in the craft comes along - are you able to measure the voltage in your battery, perhaps before and after a couple of hours on a charger? This might help identify a duff battery? 2003 4.4 HSE Epsom Green / Sand. Lovely!
Post #125789 12th Jun 2012 11:25am
What were the symptoms of the first alternator failure?
Post #125791 12th Jun 2012 11:29am
bjs
They have all been the same but the frequency is increasing (ie time between them failing is less)
The car has the battery light come on then various warning messages then slowly shuts down.... I have replaced twice since November... last one being less than 3 months... but they have until now been under warranty but they will not warranty anymore...
Does that help ? [/quote]
Post #125793 12th Jun 2012 11:48am
Might be worth having a word with these guys
Post #125794 12th Jun 2012 11:52am
barry,
battery from eurocarparts ,type 020 bosch/varta 110amphr 920 cca, discount codes in 'ebay and bargains spots' section.
a bad earth will cause surges and knacker the alternator.. ... - .- -.
Post #125795 12th Jun 2012 12:02pm
bjs
Thanks Stan, reserved the Bosch Battery as Varta not available.. 5 year guarantee so looks a good deal.. just under £100 !!!
Thanks for the nudge Smile
Post #125800 12th Jun 2012 12:22pm
Thumbs Up ... - .- -.
Post #125801 12th Jun 2012 12:24pm
I'm as we speak in the middle of changing my alternator. Currently sat on the garage floor waiting for a phone call from the garage to tell me they have my new water pump. had a slight leak so taking the opertunity to change it out. i got my new alternator for £240 and the same garage told me they could overhaul/service the old one for about £80. might be worth a though before you put you VERY expensive landrover one in. I was quoted £700 from one landrover garage and £1020 to buy it outright! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #125807 12th Jun 2012 2:16pm
bjs
Hi Rob...
Managed to get Genuine Landrover one for £400 plus VAT which I thought was a bargain... brand new....
but yes good thinking, have a friend who is good with electrics who has offered to test the full circuit, battery and alternator first, he thinks a possible bad earth too...
Thanks
Post #125809 12th Jun 2012 2:41pm
ebajema
Considering the age of your car, I think (or actually I hope) it is a bad earth somewhere. Suggest to undo all earth connections, clean them thoroughly (white metal/bright copper) and reattach. Then cover in vaseline to prevent further corrosion. Biggest problem in car electrical systems (I drove Alfa Romeo for years Smile) is bad connections, just a bit of resistance due to corrosion and you have no voltage left.
Good luck and I hope they can refurbish your current alternator. We (my dad and me) used to do that all the time, also with starter motors. Brushes cost you about 1 GBP (eq.) in Holland and the work is an hour or so (including removal and installation). Most rectifiers are also easily changed, sometimes rectifier and brushes are a single unit that you can take out and replace easily (obviously the brush/rectifier unit is a bit more expensive). MY 2010 5.0 SC Galway green and sand interior!!
Post #125812 12th Jun 2012 2:55pm
bjs
ebajema
Thanks for the thought, it's been mentioned a number of times the earthing.... will be doing that first, once happy we'll change battery and alternator...
Thanks
Post #125821 12th Jun 2012 3:47pm
ebajema
Keep us posted please, I for one am very interested. MY 2010 5.0 SC Galway green and sand interior!!
Post #125822 12th Jun 2012 3:53pm
Agree with the above ^^^. Thumbs Up
Also make a point of locating the engine block earth strap, goes from engine block to sub-frame / body.
The sub-frame / body connection is always suspect on cars of a certain age.
This earth strap also acts as the electrical return path for the alternator current from the body so it is very important it is in good conndition electrically.
Post #125829 12th Jun 2012 4:38pm
bjs
Thanks nicedayforit Thumbs Up
Post #125935 13th Jun 2012 9:55am
