![]() | Home > Technical (L322) > Is pulling the plug(s) a good idea?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35781 ![]() ![]() |
welcome to the forum..
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
Many thanks for your reply....glad to hear the All Comms will do the trick....
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Welcome,
All Comms Ordered.... ![]() ![]() ![]() |
That was my original plan, but if the short-one (the girlfriend) gets the opportunity to drive it, the faf to replug it in takes the edge of the solution.... As above, All Comms ordered from the genius that is Storey Wilson ![]() ![]() ![]() |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3243 ![]() ![]() ![]() |
Welcome saint. I know you are going to be soooooo glad you made the change up from P38. The boys on here are much more helpful than the .... Ahem, other site! Enjoy your V8!
easy solution...............Don't let her drive it |
Hi DB, Yes seems more L322 biased than the 'Other Site' so with luck will be a vaulable asset in the arsenal, and I hope to be a productive member too.... ![]() ![]() ![]() |
She did let me buy it, so would be kind of wrong to say no....but that would be the ultimate solution, and cheaper too!! ![]() ![]() |
hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165 ![]() ![]() ![]() |
cant go wrong with it mate.... excellent piece of kit....... ![]() |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 261 ![]() ![]() |
The easiest way is to motor the steering wheel into the dash as far as it will go, then adjust the seat so you can reach. The column never needs to move then. 2021 3.0 P400 Vogue
Nothing like disabling features that make the cars special and a Range Rover.... |
