![]() | Home > Technical (L322) > Bonnet - sevice position |
Scroll down on page
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
When I had the battery replaced on my last one, they said they didn't need to raise the bonnet back to get it out, have you tried? Discovery 4 HSE
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
confirmed, no need to alter bonnet at all, mine done last week. |
davidalanbatt Member Since: 04 Sep 2009 Location: lancs Posts: 11 ![]() ![]() |
Thanks for all your replies guys, I will see how I get on! |
Changing the battery is much easier with the hood all the way up, tho, and while the instructions on the rr.net page cited above work, it's much easier to take a small screwdriver and push it into the slot on the back of the ball socket and pry the spring clip that holds the ball out till it catches on the edges of the slits it rides in (not so easy to describe - look, it's self-explanatory). Do the same on the other side and you can casually walk back and forth while holding the hood and releasing the balls from their sockets,lifting the hood, and sliding the clips to hold the hood vertically into place. Takes about 42 secs to do the first time and around 27 secs henceafter. And just looking at the battery takes about 32 secs lees with the hood all the way up... |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
Changed mine with it normal last night, altho service position would have made it alot easier no doubt! TDV8 HST Sport **Current**
I refitted the battery with the bonnet in the service position and it certainly made life a lot easier!
FYi:
was this before the guy stuck his knee through your electric box? |
No, see hole:
hope you didn't pay him |
