Home > General > A little help please! Windscreen
benjj
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Hello all, im after a quick favour if possible please...
I had a new screen fitted on Friday by National Windscreens. It is not right (wind noise from top etc.) so they'll be coming back this week.
My question is this. On your FFRR can you feel the top of the screen at the top right and left of screen where the trim meets the A-frame? On this new (non Pilkington) screen I can and i'm not sure that is right. I can actually put a bit of pressure on the top of the rubber and feel the top edge pf the screen.
Any chance you could investigate yours and let me know!?
Post #126548 17th Jun 2012 2:17pm
Yep. in the top corners the main top rubber finishes @ 1 inch before the side pillar, then there is another rubber in the corner in line with the roof rail. I can lift this up and not only feel but see the top of the screen. No wind noise and no leaks though. HTH.
And you even get photos:
Think I might get some goo in there Wink .
Post #126550 17th Jun 2012 2:47pm
benjj
You kind and gentle man, thanks!
Seems that this new screen is the right size/shape then, just badly fitted.
I just want to be armed with the right ammo before I speak to them!
Post #126551 17th Jun 2012 2:57pm
Wind noise often caused by the side pillar covers not going back on properly, also check that the scuttle at the bottom is properly fixed and sealed .
Post #126556 17th Jun 2012 3:28pm
johnson1
I had exactly the same with National Windscreens. Their fitters were shockingly bad. However, after multiple attempts to fix the windscreen that had been fitted wrong, they agreed to pay a Land Rover dealer to fit a new screen. So their customer service was at least very good!
Post #126557 17th Jun 2012 3:41pm
benjj
I was loath to get it replaced but thecrack just kept on marching...!
The NW guys were actually very nice and switched on, I guess that a piece of seal has been missed along the top edge? Ive looked over all trim pieces and they seem to be fitted correctly.
Thanks again all.
Post #126562 17th Jun 2012 4:09pm
johnson1
Some issues you need to clarify:
- The clips that hold down the A-Pillar trim are not reusable. They attempted to do this on mine and the trim came dislodged on the motorway when wind got underneath the trim. They MUST use brand new Land Rover clips.
- On mine, the fitter snapped where the clip fits into the trim so they tried to glue the trim down instead. Didn't work.
- The screen on mine looked flush but in fact one side was slightly proud so the trim could not physically be clicked down properly.
Check all this!
Post #126564 17th Jun 2012 4:26pm
benjj
I think I've narrowed down the snafu to the middle of drivers side at the top. Pretty sure its a bad seal up there. Will find out soon enough, I'm going to watch closely what they do on the repair. Thanks all.
Post #126583 17th Jun 2012 6:24pm
Windscreen Dave
United Kingdom 2003 Range Rover Vogue Td6 Alveston Red
I fit at least 2 of these windscreens each week you have to be extremely careful on the positioning of the screens and also the top trim if they are not located within 2-3mm of the the correct position they lead to terrible wind noise and also looks unsightly with top trim not reaching rain gutter trims. Personally I only get Pilkington glass for these jobs as it seems to be the only one that fits good. As other people have said always make sure that they replace all the clips on the A pillar mouldings with genuine and check that scuttle panel is secured properly with wipers in correct position. I have had to go out and rectify quite a few of these jobs that large national companies have done the problem is that their fitters are very time constrained and don't have the time to take their time and do the job properly. My advice stand and watch and ask as many questions as you want if they are a competent fitter they should be more than happy to oblige.
Post #128282 28th Jun 2012 10:51pm
Good advice Dave...
Craig...
Post #128308 29th Jun 2012 9:26am
