Home > Technical (L322) > Will this key work with a l322?
Tuts
I know all the buttons won't work but could this be programmed to work for a FF? I need a spare and like the look of this.
http://www.ebay.co.uk/itm/ws/eBayISAPI.dll...EL:GB:1123 2003 Vogue 4.4 V8 Java Black
Post #126485 16th Jun 2012 7:59pm
You need to buy a key from the dealer
Post #126486 16th Jun 2012 8:00pm
Tuts
Why? If this is a genuine (and unprogrammed) key why do you HAVE to buy it from a dealer? I understand that they will need to program it which will cost £40 ? (or am I completely wrong here Sad )
Also - What about a second hand key? (get a new blade cut) can a dealer re-program a key that was originally used in another range? 2003 Vogue 4.4 V8 Java Black
Post #126490 16th Jun 2012 8:07pm
Well if it was that easy all the scumbags out there would be buying up the second hand keys from ebay and programming them then stealing our vehicles.
You need to buy spare keys from the dealer, but need to show proof of ownership by taking the V5 a driving license and a utility bill along when ordering
Post #126491 16th Jun 2012 8:18pm
daveo
it is a complete different system,wont work and will never work, your car is the bmw system and that remote is the new ford keyless system,you can only get the modded 2006 flip style key. V8 facelift Range Rover Autobiography 22" wheels.
Post #126493 16th Jun 2012 8:26pm
Tuts
Eh? How can they if your saying they only work for your car once programmed by a dealer and the dealer asks for loads of I'd and proof of ownership to PROGRAM the key so it would work with your car (quite rightly too) 2003 Vogue 4.4 V8 Java Black
Post #126494 16th Jun 2012 8:29pm
Tuts
Cheers Dave didn't realise it was a keyless system one (does that mean that key wouldn't even have a blade !)
so can I go to LR and ask for a new 2006> flip style key for my 2003 ? Or are they not likely to do that? 2003 Vogue 4.4 V8 Java Black
Post #126495 16th Jun 2012 8:33pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Also ... it's not a key, it's a keyless smart 'key'. There is no blade (well there is, but only for emergency purposes to manually open the door - and it's loose inside the fob). Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #126496 16th Jun 2012 8:33pm
Unfortunately LR will give you the same Censored as you have now. You can get an aftermarket 2006 style copy that will work. Have a search for "flip key" and you will find a monster thread all about it from recently. Getting keys to fit and turn is by all accounts easy. BUT you need the little chip inside to in immobilise the alarm. It's this chip that LR charge you a fortune for as they are coded to your car and come from Germany. You can change to the BMW dimond key quite easily but that still looks Censored . Best option to date is a 2006 flip key copy. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #126499 16th Jun 2012 8:55pm
daveo
if you have the early style key then there are a few option, but no good going to the dealers as the will not order you any other key then the one that came with the car, NOTE.. don't bother buying a secondhand key unless you want to rip it apart to see how it works,been there done it..you can not reprogram a used key,they are programmed only once, you can sync it to your car to open the doors but that's it...again that will be only for the early keys.
all the later keys work on a different system. you can get a modified 06 flip style key to work but it is not a standard key it has a modified circuit board.if you do a search it will be there V8 facelift Range Rover Autobiography 22" wheels.
Post #126504 16th Jun 2012 10:14pm
enumbers
Ireland 2004 Range Rover HSE Td6 Adriatic Blue
http://www.ebay.co.uk/itm/BMW-PCF-7936-TRA...5893850c14
Would this chip work as it is new could it be programed
Post #126542 17th Jun 2012 12:46pm
Possibly but not 100%. What exactly do you want from a new key? Would you be happy with no remote central locking but a key that looks good to show off down the pub? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #126546 17th Jun 2012 1:30pm
daveo
ID 44 Philips Crypto blank chip
Code: TRA-AT21
PCF7935AS blank chip Silca Code: not available
as above these are the programmable chips in my keys, they are Philips so i would think the ones on ebay will work, V8 facelift Range Rover Autobiography 22" wheels.
Post #126569 17th Jun 2012 5:19pm
enumbers
I would be happy to have a spare key that gets me into and starts the jeep 2004 td6 Adriatic Blue
Post #126598 17th Jun 2012 7:50pm
jeep ? ... - .- -.
Post #126599 17th Jun 2012 7:51pm
