![]() | Home > Maintenance & Mods (L322) > Heater fan lubrication ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
it appears that the vents just pull out so possibly you might gain access to the motor that way..
Don't be silly Stan, it's a Range Rover...
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
You mean blunt and to the point Stan |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Back to the OP the fans can be accessed a bit if you take out the pollen filter box in the engine bay, remove the seal and then 2x 13mm nuts and just pulls out. You can then get access to the two. If holes and the fan inside. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
^^^ Spoilsport |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
However you get to the fans, you might want to actually use a LUBRICANT instead of WD-40.
According to RAVE, fan motor access is 5 steps, as follows:
So my post was almost correct then |
pretty close.
so it'll be squirting wd40 into the intake then... |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 744 ![]() ![]() |
I think it'll be putting it in position 2 onwards, where it's nice and quiet |
