Home > Maintenance & Mods (L322) > air suspension and door card help |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 |
hi
7th Feb 2010 9:57pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
how do you know its the pump ?
8th Feb 2010 7:10pm |
i agree that if nothing else EAS should be left to the dealers as there are so many varables and faults to think about
8th Feb 2010 7:25pm |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 |
thanks for the help do i need to worry about the air bag in the door when removing the door card |
well just spent all night replacing my caravan tow socket and passanger window switch panel (as it had pealed)
8th Feb 2010 10:56pm |
the air bag is bolted to the door metal and what your doing will not require its removal however i had no ignition key in and was mind full but i had no worries and i took mine off 02 Range Rover HSE Zambezie silver 4.4 |
8th Feb 2010 11:03pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
Hey, +1 on the dealer diagnostics... That said if it's got a new compressor and it's still raising slowly check all the pipework, particularly return pipes/collector pipes.
9th Feb 2010 1:17am |
well this started to bug me again so i got it checked over today ,the computer still says brush core temp to high (199)
3rd Mar 2011 9:34pm |
