Home > Maintenance & Mods (L322) > Smokey Exhaust
Page 2 of 3 <123>
Elena
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Do you reckon its more likely to be the rings etc rather than the breather tube assembly because the smoke is blue. I don't think the previous owner took much care with this car and my friendly mechanic is too scared to give me the bad news. I just want to drive her, she is the cleanest uunused car in my street.
I will keep you informed.
Regards
Elena
Post #126965 20th Jun 2012 11:20am
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Just to rule out the td6 engine does appear to smoke under acceloration but its mostly noticeable at night when you look in the rear view mirror
Mine did and i did an oil change removed / blanked the egr and replaced the crank case breather and its never smoked again at night or under load
The above is cheaper than turbo or rings and worth a try
On the egr valve get the allisport one as its a perfect fit and guaranteed for life i believe onto no6 Range Rover
Everyone needs a hobby
Post #126973 20th Jun 2012 11:52am
Elena
It's a thick heavy blue smoke which stinks. I can start the car, no smoke, drive for a mile lots of smoke, pull over and let the idle until the smoke stops then carry on with my journey and no more smoke. But I am too scared to drive her at the moment until I know I am not making thingsorse. Big Cry
Post #126979 20th Jun 2012 12:35pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
have you changed the breather yet? if not theres no point worrying until you have. most common cause of burning oil and turbos being replaced unnecessarily on all bmw engines is the breather being blocked causing excessive pressure in the engine forcing oil and pressure out were it can which is normally the turbo seals and valve stem rubbers casing alot of smoke out the exhaust.
Post #127080 21st Jun 2012 12:24am
Elena
Hi Arron, not yet. The mechanic I know really well works for Vauxhall and is waiting for his friend who works for Land Rover to let him know what to do. I think I will order the breather tube assembly and ask him to start there. The trouble is I don't want to tell a mechanic what to do, especially a mechanic who doesn't like forums. But you guys own these cars and know what you have done to put things right, perhaps I will have a go myself.
Cheers
Elena
Post #127086 21st Jun 2012 6:45am
Better having the Vauxhall mechanic fix your FFRR, the Land Rover mechanic won't have a clue what he's doing Whistle
Post #127087 21st Jun 2012 6:54am
Elena
Probably right there, it's amazing that they have never had a car in that smokes or never worked on the EGR valve Shocked
Post #127089 21st Jun 2012 7:39am
Your money your car! Mechanic should do whatever you tell him. Worst he should do I say "told you so". Know which option I would be doing. £40 on a breather or £1kish on turbo pistol rings? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127091 21st Jun 2012 8:07am
Elena
I am not being forceful enough, he should know how impatient women are, if he doesn't come back to me today then I will have a go myself at the weekend as I can't wait any longer.
Post #127098 21st Jun 2012 8:52am
speedymarktd6
Ifu get stuck just let me know i will try too help Thumbs Up onto no6 Range Rover
Post #127106 21st Jun 2012 10:38am
Elena
Breather assembly ordered and car booked in tomorrow, yippeeeee
Post #127241 22nd Jun 2012 8:50pm
Elena
All done and Smokey Jo is no longer Smokey . The filter was absolutely solid , why aren't these changed during normal servicing . Now onto the next project.
Thanks for everybody's advice , cheers Very Happy
Post #127312 23rd Jun 2012 5:02pm
result Thumbs Up glad it didnt turn out to be more costly... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #127331 23rd Jun 2012 7:59pm
ahebron
New Zealand
Elena wrote:
.... The filter was absolutely solid , why aren't these changed during normal servicing . Now onto the next project.......
Because the parts changers can't be arsed to do it. And if it isn't mentioned in the schedule then it isn't done. Lets not start about changing TD6 gearbox oil.
Adrian VW Amarok 2014 Highline auto
Post #127371 24th Jun 2012 9:32am
Elena
Oh no, how often should that be changed Adrian, . I bet that hasn't been touched
Post #127409 24th Jun 2012 1:43pm
Page 2 of 3 <123>
