![]() | Home > Technical (L322) > Front wipers don't park at bottom of screen |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1040
I had exactly the same problem (which cured itself on a couple of occasions) but then a few weeks later my wipers decided to just stop whenever they felt like it. I would definitely recommend that you try replacing the £6 relay first before moving on to the more expensive stuff.
| 993porky Member Since: 25 May 2011 Location: Sunderland Posts: 58
Thanks phil for your reply I'm going to try that relay al get one ordered on Monday,do u think the relay would stop the wipers parking at the bottom of the screen ? Cheers paul Range rover hse
| Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700
How did you fix this, I have the same issue? |
| Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156
Unfortunately I think your wiper motor is on the way out.
Hmmm shame ..... Still under warranty tho.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
try turning off the ignition when the wipers are in the park position.. ... - .- -.
Sorted - checked under the bonnet and you can see the motor and linkage quite easily behind the bulkhead on the drivers side.
