Well, the smell I've been ignoring for a few months, presuming as I overfilled the power steering and had to syphon some out, and it had run down the block causing a smell..........
...turns out to be a diesel leak from one of the pipes under the engine cover.
It was not what I'd call exactly a diesel smell, which is why I wasn't sure, but then decided if it'd been the power steering fluid, it would have burnt off by now...........
So its my own fault for leaving it, which is a bit not like me, but its booked in my local Land Rover specialist on Thursday morning (2 days time) and they recon that either the pipes will need "tightening up" or that they have started to split, and will be replaced.
Has anyone had to change theirs ?
The garage will also have a quick look at my squeaky rear suspension, and see which bush is causing the issue.
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
