Home > Maintenance & Mods (L322) > Poll. What pressure cap is fitted to your M62 V8
Which one are you?
Big and meaty - 200
50%
 50%  [3]
Less is more - 140
50%
 50%  [3]
Total Votes: 6
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
There is a lot of confusion about what is correct.
Parts sheets all say 140 (1.4 bar) is the correct replacement.
Common sense (and many owners) say the 200 (2 bar) is correct...
Which one is fitted to your Petrol V8 (BMW Engine not the Jag engine -so per-touch screen petrol cars only)
The number is either embossed on the top of the cap, or else on the bottom. The 140 has a yellow insert visible a the bottom, the 200 is all black.
Post #127840 26th Jun 2012 8:12pm
Once you have had black you will never go back! 200 on mine. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127897 26th Jun 2012 11:33pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
200 on mine too - August 04 BMW petrol 4.4
Chris
Post #128003 27th Jun 2012 4:13pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
Mine has the yellow insert.
US-spec, 2005 model year.
Since there seems to be some difference between US model year and UK model year, mine is the last year with the BMW M62 engine.
Touch-screen nav, just to further muddy the waters. Jim
2000 NAS HSE
2005 NAS HSE
Post #128291 29th Jun 2012 4:04am
gunnar-L322
Sweden 2003 Range Rover Vogue 4.4 V8 Giverny Green
I replaced my 200 last winter with a 140 since everybody said 140. But that was when the problems began.
After much confusion with an incontinent L322 I looked at my old cap today and it reads 200 !
I replaced the 140 with my old 200 cap now (lucky I had not discarded it) and I agree black is the way to go. Radiator hose pressure is high at 105 celcius so important to have fresh hoses to increase chances for engine survival.
Some advocate for modifying so that the thermostat pre-heater is on at all times while ignition is on so the engine always run at the colder setting.
But this gets fierce advocacy posts from people who defend why the design needs to be the way it is. /gunnar L322 Vogue V8 -03 Giverny Green
Post #128611 30th Jun 2012 1:51pm
ebajema
The design could be to reduce emissions and not because it is "better" for the engine. Not saying that it is like that here but could be. Same with the fuel system programming, they are based on improving the emissions (based on the standard tests) and that is not always optimum driveability. MY 2010 5.0 SC Galway green and sand interior!!
Post #128615 30th Jun 2012 2:29pm
Tuts
140 on mine. 2003 . Gulp should I be worried? 2003 Vogue 4.4 V8 Java Black
Post #128656 30th Jun 2012 7:01pm
Do you have any problems at 140? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #128667 30th Jun 2012 8:27pm
Tuts
It's on it's second engine! Due to overheating Whistle (previous owner replaced the engine) . Current engine sits in the middle of temp guage and doesnt move a bit. Does seem to use a very small amount of coolant though (its also had a very recent water pump, rad and hoses so i know they're not leaking - maybe time to upgrade to stop the minor loss but on the flip side though I don't want to fit a higher pressure cap and blow some hoses! 2003 Vogue 4.4 V8 Java Black
Post #128669 30th Jun 2012 8:44pm
