![]() | Home > Maintenance & Mods (L322) > dont believe what i have just done !! |
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
Guess you are meaning this part
| highfellzippy Member Since: 20 Aug 2011 Location: Yorkshire Posts: 153
yes thats the ones totally |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Rub down with grade 400 wet & dry then grade 1200 then grade 2000 or 3000 would be better, then polish up with cutting compound then polish and wax |
nice thought but the nitro has eaten them |
Surely cant have eaten right through, it has to be worth a try |
| BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429
I replaced this in my old range rover. It's not the worst job to do and I think it cost 30-40 quid |
Yes they are available new without the switches... We fit loads of them...
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837
You'll need to take the door panel off to replace it! |
have tried rubbing them down after 2 hours they are looking ok i may have a go at painting them tomorrow |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
There is a post on here tonight about spray on rubber finish for them, will look pretty stock then.
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244
Yes I was reading that Plasti-Dip is a spray coating that will put the rubber feel back. It is used on many BMW and Land-Rover parts. Tom
sod it
| All times are GMT |
