Home > Maintenance & Mods (L322) > Useful gadget for fitting an accessory in car
Useful little device if you have need for a fused, ignition controlled 12V supply inside the car for an accessory.
Pick an ingition controlled fuse in the fusebox, remove the fuse and insert in piggy back fuse holder, fit accessory fuse in holder and insert holder into removed fuse space. You then have a connection available for the accessory circuit.
Piggy back fuse holder
Post #128311 29th Jun 2012 9:35am
Nice... Don't need one just now, but gonna buy one for the toolbox anyway.. Thumbs Up Previously..
Post #128313 29th Jun 2012 9:40am
Good find sir... Thumbs Up
Craig Bow down
Post #128315 29th Jun 2012 9:44am
just what i need , thanks.. Thumbs Up ... - .- -.
Post #128321 29th Jun 2012 10:10am
kay323
That is great little device, saves a lot of time routing/cutting wires.
Post #128337 29th Jun 2012 11:39am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Nice find, keeps things tidy! Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #128483 29th Jun 2012 9:45pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Geez - I could use a few of those - nice!
Post #128722 1st Jul 2012 11:20am
It may be of interest to anyone fitting an accessory to the car and needing an ignition controlled 12V supply that on a TD6 (>2005) and possibly others for that matter Fuse 7 on the front fuseboard is unused and is ignition controlled.
The cabling to it is rated at 5A, more than enough for most accessories.
If you use one of the "piggy back" fuse holders you will only need a 5A fuse fitted in the accessory fuse position, you won't need a fuse fitted in the origonal circuit position.
This means that the fuse 7 circuit will still be unused and unfused which means that anything that happens to be connected to it will still be dead as origonal.
Hope this is of some use.
Post #129131 3rd Jul 2012 9:29am
great info ,thanks.. Thumbs Up ... - .- -.
Post #129132 3rd Jul 2012 9:30am
This might be of some help:
Please note, for the first picture description, a fuse inserted in the lower holder won't make a circuit out, but it will protect the original circuit from the main fuse connector. In the second picture, with the fuse in the top holder, a circuit out is made, but the original circuit on the main fuse connector is unprotected and not complete.
Post #151787 18th Nov 2012 10:09am
