![]() | Home > Technical (L322) > Help - Won't start |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
Your battery is flat.
Alex 111s Member Since: 09 Feb 2010 Location: Aberdeen Posts: 14 ![]() ![]() ![]() |
Ta. will check when I get home tonight. Had a flat battery a couple of weeks ago but it let me turn the engine over then. (not even getting that far this time.)
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
It seems the cold weather has caused a lot of battery issues for a number of members and the advice I think everyone would echo is, if your battery starts giving you problems, you can bet your last pound it won't get any bettter.
Thans to both of you for the advice.
As RRUK's post your best replacing it or you'll end up paying for fault codes reset like I've just had to do.
It's worth checking the voltage, with the engine running. It should be around 14V, even with accessories on. Although if I load everything up 4 heated seats heated screens, steering wheel, blowers, lights etc it drops to below 12V at idle, but picks up to just over 13 over 1000 rpm.
