Home > Technical (L322) > Where can I get spacers ?
J.Seven
Portugal 2003 Range Rover Vogue Td6 Monte Carlo Blue
Want to put spacers on my TD6. Where can I get it and which size are available ? J.Seven
Post #79960 8th Sep 2011 10:25pm
ebay, about £185 http://www.ebay.co.uk/itm/Terrafirma-Range...335d711266
Post #79963 8th Sep 2011 10:34pm
J.Seven
Thanks.
Anyway 30mm seems a little to much, I don't want the wheels to stick out the arches. Does Land Rover sell spacers for these cars? J.Seven
Post #80067 9th Sep 2011 2:47pm
not as far as i know.....
Post #80069 9th Sep 2011 2:52pm
duckworthparts
Site Sponsor
definately don't do any genuine spacers. You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #80070 9th Sep 2011 2:53pm
Spacers will cause extra stress on wheel bearings and other suspension components
Post #80074 9th Sep 2011 3:30pm
Amazing how many wheels have been known to come off as well when fitted with spacers.
Post #80075 9th Sep 2011 3:34pm
Down to nuts being to short or the spacers themselved ?
I would have thought that if you changed to longer nuts to compensate for the spacer then there shouldn't be a problem.
Happy to be corrected though......
Post #80148 9th Sep 2011 9:14pm
the spacers are bolted onto the hub using new smaller nuts and using the existing stud holes...that leaves the spacer studs for the wheel to locate onto and be 'nutted'..
Post #80161 9th Sep 2011 10:11pm
rmackinnon
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Does anyone have a photo of their L322 with these on before and after? FFRR 2003 Vogue V8
Post #128684 30th Jun 2012 10:52pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
I wouldn't touch them for the reasons mentioned already - extra stresses on the wheel bearings, and wheels falling off - which is probably why they are completely illegal over here.
Post #128714 1st Jul 2012 10:52am
I know this sounds like ganging up on a fairly innocent post but I can't for the life of me see why you would fit spacers , the standard wheel offset is correct for the vehicle putting these thing in put a ( very ) week link in the drive train and at the same time increase the load to the same drive train whilst simultaneously changing the steering geometry increasing bump and torque steer . So all round a bad idea . 2008 MY Supercharged
Post #128730 1st Jul 2012 11:56am
i can see where the attraction is , the rears on the range seem to not fill out the arch properly so fitting 30mm spacer would make it look better..as for strain on the wheel bits/drivetrain etc , i cant see that as the range is very well built.. ... - .- -.
Post #128731 1st Jul 2012 12:06pm
verydisco
Not a fan on a road-car (ok on a dedicated offroader I guess)
Simply get the wheels you want with the appropriate offset to beging with.
However, I have NEVER heard of someone loosing a wheel because of a TüV approved spacer. Let me know if you do please. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #128747 1st Jul 2012 1:05pm
wheels with a bigger offset and rim width do look better on the rears but to wide on the fronts, hence the spacers on the rear idea.. ... - .- -.
Post #128762 1st Jul 2012 3:56pm
