![]() | Home > Maintenance & Mods (L322) > Got new style flip key to work..! |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
hi, blanks are in and i will post out, please make payment... V8 facelift Range Rover Autobiography 22" wheels.
| robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467
cheers Dave, thanks for getting a source of the blank for everyone. Current vehicles
I called Timpsons Head ofice and explained I wished to have a blank cut at my own risk at a local branch, customer service was very helpful, contacted the branch and they agreed to cut it for me at my risk.
well, got the manager to program a Timpson T4 chip for me at the same time, so key cut plus a spare blade and coded chip for £40.
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Dave, you're right about the blade, if cut too short it rubs. Mine is only just clear. Still can't use it to open and close the doors though, despite the fact that I have it on the North American frequency. |
sounds like you need to let it charge up with the engine running with it in the ignition, at least 2 hours, then follow daves programming steps. Current vehicles
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737
i have my new flip key all cut and assembled, programmed it in the car and it opens and closes the doors fine but wont start the car, i have put the original transponder from my old spare key into the new flip key - the car starts fine with my original old style key and if i then try and attempt to start the car with the flip key it works and starts the car fine but if i try and start the car with the flip key after opening the car with it, it will not start?? any ideas??
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244
The transponder ship is very sensitive and needs to be as close to the edge of the fob as possible, even a few mm difference cause the car to lock up if not in the right position. There should be a slot to perfectly match the transponder chip and keep it in place on the fob under the rubber inlay.
the chip is also directional, so ensure you fit it in exactly the same orentation as the original key, you can prove it by just holding the chip near the ingnition hole area, you will hear the unlock of the barrel to allow turning.
robbo, so how did they program your chip, i was told that it had to be programmed with the car.. V8 facelift Range Rover Autobiography 22" wheels.
the Timpson T4X chip I bought to allow me to keep my original key as a spare as well,
so did there chip fit into the new key ok... V8 facelift Range Rover Autobiography 22" wheels.
I had to remove the support that acts as the stop for the slot for the land rover shaped one under the rubber inner slave.
do you mean timpson the key cutting shops? it is starting to look like the new flip key has some how fried my original transponder chip as it wont even work back in the original landrover key anymore (it worked perfectly this afternoon no problems)
