![]() | Home > Maintenance & Mods (L322) > Got new style flip key to work..! |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
Yes. Timpson key cutting shop,
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
yes tried putting my original transponder near the ignition but it doesn't do anything anymore (no more clicking noise unlocking the steering column) i dont have a spare key anymore as the transponder that i used for the flip key came from my spare, i have got the blade cut for a fiver but now i need a new transponder. No didnt insulate it as the one that came with the key wasnt insulated so didnt even think about doing that! dam!! |
You still got 1 working key? Current vehicles
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Haven't done anything with mine yet but slightly worried now. Do you have to wrap the chip in tape or is that just a precaution to stop it touching stuff in the key. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
robbo, what branch did you use.. V8 facelift Range Rover Autobiography 22" wheels.
There is one on the boards when you get them, these are covered in a sticky tape all over.
I used one at Berryden in Aberdeen,
is this the one..
That's the one you guys want. Current vehicles
So the new key has a transponder coil in it? That's what if covered with ape? Haven't really looked at mine as need to get he blade cut. Can any Timmons do chips and laser cut keys? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Yes, but they will refuse to cut the key , unless you speak to HQ first for authorisation with a no liability agreement on the cutting of the key.
Matt, is there an "original" transponder in the new flip key ?? I used a second hand key with a transponder, together with a transponder of an old key of my car. Didn't work so I removed the transponder of the second hand key and it worked. Also the transponder needs to be very close to the lock, in the old style key it is at the edge of the housing. MY 2010 5.0 SC Galway green and sand interior!! Have the Faultmate MSV2 Extreme to be tinkering with the settings etc. !! |
Daniel2007VogueSE Member Since: 30 Jul 2012 Location: Singleton NSW Australia Posts: 17 ![]() ![]() ![]() |
Hi guys, I need a bit of help with this one ...
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
One question: when gluing the two parts together (which certainly is needed, since there is no screws to hold the top and bottom parts of the flip keys together otherwise), how can you replace battery in the flip key in the future? Last edited by Eirik34 on 6th Nov 2017 10:28pm. Edited 1 time in total |
