![]() | Home > General > Help - broken down in Calais! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35720 ![]() ![]() |
dont know about the glovebox but if it doesnt turn over it could be the battery.. ... - .- -.
Can you get a cheap voltmeter and check the battery voltage ?? Also, disconnect the battery for 10 mins to reset everything. Are you sure your key is OK as in the battery in it is fine (does it open and close the doors ??). MY 2010 5.0 SC Galway green and sand interior!!
I would bet good money your alternator's goosed. Mine did EXACTLY this, on my way to a job interview no less. No warning, no red light, just a crap load of errors followed by changing to 4th gear and staying there until the last thing to die was the fuel lift pump, which was game over.
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Have you double checked it is correctly in Park? Even if it appears to be, move it into drive, and back into Park, if you're getting nothing at all, then it's probably that the car believes that the safety criteria for starting the car have not been fulfilled. It's happened to me before! 2012 SDV8 Vogue SE |
Wouldn't stop the gloveboxes opening Boz. Only lack of electrons will do that. |
Missed that when I read about the problem, wow, does the glovebox really need current to open? |
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 ![]() ![]() ![]() |
If you get really stuck. Send me a pm. My mate lives in Calais and has a very good garage on the outskirts that may be able to help 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
Yes unfortunately for you from 07MY the glove box button is electrically powered. |
Ukdave104 Member Since: 26 Apr 2012 Location: Aberdeen Posts: 116 ![]() ![]() ![]() |
But in his post he says that "electrical power for all things seems to be ok" |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1230 ![]() ![]() ![]() |
Is he still there? Tom
it would be nice for the OP to let us know whats happening.. ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7931 ![]() ![]() ![]() |
he'll be on one of those bicycles now, with the basket and the onions and a beret.................. 2011 Range Rover Vogue SE 4.4 TDV8
WelshCH Member Since: 27 Nov 2011 Location: Vaud Posts: 9 ![]() ![]() ![]() |
Hi All
Glad to hear all is well! Tom
