Home > Wheels & Tyres > Advice please on wheel change
Elena
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Hi Guys
I currently have 265 60/r18 110h tyres on my car. The car is on the 56 plate and I was wondering what 19 or 20 inch wheel/tyre combo could be used to replace these ones. I look forward to any replies.
Cheers
Elena
Post #130237 10th Jul 2012 11:31am
You should have 255/60/18 as standard
If you wish to upgrade keeping standard sizes then you want
255/55/19
255/50/20
Post #130239 10th Jul 2012 11:40am
Elena
Hi thanks for the speedy response, would you go for the 19, 20 or stick with the 18 inch. Any ideas why I would have 265 tyres on my car and not the standard 255?
Cheers
Post #130244 10th Jul 2012 12:08pm
i had those on mine elena, i think LR brought a cheap batch of them during 2005/2006 ...
because yours is a td6 you will find that when stationary and in drive the car will vibrate a bit if you on 20'', nothing serious but annoying and you'll get in the habit of clicking into neutral when at traffic lights...
i'm on 20'' but if i had the chance ,i'd stick 19'' on which stills gives a comfortable ride and look good ... - .- -.
Post #130247 10th Jul 2012 12:15pm
Elena
Hi Stan thanks for the advice, watching some 19 inch ones on eBay. Does the spare have to be the same size wheel etc.
Cheers
Post #130251 10th Jul 2012 12:40pm
the spare doesnt have to be the same but its desirable for it to be... ... - .- -.
Post #130252 10th Jul 2012 12:46pm
19s are a good upgrade for the TD6 without making for too harsh a ride, also a bit less tyrewall reduces the cornering roll effect
Steer clear of 20s though
Post #130255 10th Jul 2012 1:25pm
Elena
Hi, thanks for your advice just bought a set of 19 inch wheels with tyres. Do I need to have the suspension settings set to anything other than normal before changing the wheels please, may be a silly question but thought I should ask it, cheers.
Post #130269 10th Jul 2012 3:03pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Hi Elena
I am sure there are issues with what type of wheel nuts are required depending on the age of vehicle and wheels but I am sure someone who knows will supply the correct information soon ( or do a search)
ditto for jacking up. Mine was a blue one! Smile
Post #130272 10th Jul 2012 3:23pm
Click for wheel nut info
Post #130280 10th Jul 2012 4:25pm
enumbers
Ireland 2004 Range Rover HSE Td6 Adriatic Blue
Stan why is there a vibration issue on the td6 with the 20s on 2004 td6 Adriatic Blue
Post #130338 10th Jul 2012 9:32pm
Don't know the reason for the vibration with 20s on the TD6, but LR do not recommend fitting them.
Post #130340 10th Jul 2012 9:34pm
@enumbers, its the change in inertia and stiffness of the wheels allows a torsional resonance through the driveline from the engine firing pulses... ... - .- -.
Post #130356 10th Jul 2012 10:06pm
enumbers
Cheers for the explanation its crazy that the reduction in flex in the tyre wall would cause a noticeable effect 2004 td6 Adriatic Blue
Post #130587 11th Jul 2012 8:53pm
