![]() | Home > General > Custom Russian Armored FFRR |
| M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325
Nice, Dash in the back works quite well, better than a plain divider. |
| nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2075
Nice, pity no dual screens.
| 3R10 Member Since: 17 Oct 2009 Location: Paris Posts: 324
as far as I've seen, the RR is 400 mm longer than the original L322, so I guess there is no real problem for the driver! Anyways, I think these are aimed at rich millionaires... |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
looks like a bodge job to me. Other manufacturers would make a bespoke rear unit not use the original dash!
I agree with your opinion, however I kinda like the way the used the dash! It kinda gives the OEM look! However, not seen too much bespoke Range Rovers which are this different! Apart from this one! The Mayfair Edition RR only adds a glass ceiling, and two lounge type seats with 300mm or 600mm longer RR options! This is kinda different! you can check the 360 degree panorama here http://pano.1drey.com/panos/cars/rover_flash.html 2000 BMW M5, Avus Blue/LeMans Leather Interior 2006 Range Rover Westminster Java Black |
Rubber mats in a limo - urgh |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
The rubber mats will be to keep the blood of the carpets |
