![]() | Home > Technical (L322) > Transfer box neutral warning message |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
You didn't knock the Hi/Low range switch by mistake (causing the "Put gearbox into neutral" message) ? |
misteralz Member Since: 30 May 2012 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
No, I've done that deliberately in traffic and seen that message before. This definitely said 'Transfer Box Neutral'. Just flashed up for a moment and was gone. 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten... |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Its just messing with you cause it can |
It will be a muddy brown colour |
Mine looked more like black treacle in colour, nearly black but still translucent, but not that thick in consistency |
And the transfer box fluid? Mine was a blue one! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
touché |
KARMANN Member Since: 13 Dec 2010 Location: Scotland Posts: 95 ![]() ![]() |
If this appears its more than likely to be the electric motor that actuates the hi low. Mine has done it from time to time-ive removed it. Tested it on a bench and replaced it and it works fine. Theres a sensor inside it thats suppposed to communicate pretty mush saying what position its in and if its working. This sometimes plays up causing this issue. As i said before-three bolts undoes it and one electrical connector. Just by removing it putting 12v across it a little lubrication and refitting it has always worked for me. the other option is to pay £700ish for a new one. The sensors cant be purchased seperately.
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 ![]() ![]() ![]() |
Just started to have this problem myself |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1031 ![]() ![]() |
That message should only appear if you insert a fuse into position 37 to prevent the transmission output shaft being driven if the car is towed on all four wheels.
socialrover Member Since: 03 Dec 2010 Location: Yorkshire Posts: 141 ![]() ![]() |
Hi Phill ,
