![]() | Home > Technical (L322) > Air suspension compressor repair |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I'm going to strip and rebuild my air compressor this afternoon. In short, how do I remove the compressor? When I say remove, I mean is it just a case of unplugging the electrics and the air pipe or should I be draining the air first and if so, how? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
havnt read through these but there might be something that might help,
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Noddy if you have a RAC or IID tool just unplug it and the air line. You should only get a small hiss. If you don't disconnect the battery first then unplug. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
When i fitted my lpg tank the suspension was in normal height i just unplugged the hose from the compressor
Yes, I've got the bolts. Thanks. Rebuilt it all today do I just need to get the fault cleared 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
... give me info about the fitting-repair, was it easy? L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
