Home > Technical (L322) > Secondary Fuel Pump TD6
Was out this morning in the FFRR and back home, switched the engine off and half an hour later went to start it again, it just turned over. A quick look under the bonnet at the fuel pipes and they all looked full with no air bubbles, so off with the cover plate for the secondary fuel pump (just in front of the n/s rear wheel) and switched the ignition on, all was quiet so a soft tap with the spanner brought it back to life.
Will be fitting a new pump tonight, so may post some pictures
Post #130658 12th Jul 2012 10:19am
Are you going to disect it? if somethings sticking how clean is the tank as if its just sucked some gunk thru that could have stuck in it and the tap has dislodged it or repaired a loose connection??
I know its mitigating the risk failure after a repair but root cause analysis is the best way to go to me Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #130671 12th Jul 2012 11:12am
I may dissect just to see what is inside. Most likely the pump is worn as it looks to be the original Pierburg BMW part
This is the original Pierburg BMW pump
The pump is located just in front of the off side rear wheel under a plastic cover. There is no need to remove the complete cover as there is an inspection cover underneath held on with 2x10mm bolts
Once the inspection cover is removed you have access to the pump which is held in place by two phillips head screws
One pipe to the front and one to the rear and an electrical connection to the front
The hose clips are of the type that are a swine to work with so I removed them and fitted fuel line clamps size 12-13mm which made refitting a lot easier
Once everything is reconnected start the engine and check for leaks
Refit the cover, job completed
Post #130787 12th Jul 2012 9:55pm
Yes there will be fuel drips out of the lines. Yes the said fuel will run down your arm onto your clothing, the floor/driveway and make you smell like an HGV mechanic Whistle
Post #130788 12th Jul 2012 9:57pm
Clean it out using petrol... Works for cleaning diesel off/out of most things...
Craig Thumbs Up
Post #130798 12th Jul 2012 11:08pm
The pump is a common failure on the TD6, so at 124k miles I think it makes sense to replace
Post #130800 12th Jul 2012 11:50pm
Admit it you are just rebuilding that car from scratch Razz
Post #130801 12th Jul 2012 11:51pm
Feckin feels like that Mick Big Cry
Post #130802 12th Jul 2012 11:55pm
That must be the only 124,000 mile new car that I know of Laughing Thumbs Up
Post #130803 13th Jul 2012 12:03am
Once I get it the way I want it I'm going to sell it Laughing Laughing
Post #130805 13th Jul 2012 12:19am
nice little 'how to' there john, thanks for the info.. Thumbs Up ... - .- -.
Post #130819 13th Jul 2012 9:28am
Ah, memories of the SU electric fuel pump on my 1965 mini traveller. Often amused my passengers when I had to jump out, hit under the rear of the car with a hammer, jump back in and start up and away Smile
At least they have made it accessible on the FFRR .
Post #130822 13th Jul 2012 9:38am
Dissected the pump tonight, there are two filters inside, one at each end, no dirt was present in any of the filters. I would hazard a guess that the pump had run its course and the lifespan just about expired but I will have a closer look tomorrow and will post up some pictures.
Post #131115 14th Jul 2012 9:49pm
As suspected there really isn't much to see and certainly nothing that looks to cause the pump to stop. I can only guess that the electric motor has reached the end of its life.
Post #131184 15th Jul 2012 12:41pm
I've now stripped the motor right down, the commutator is worn out and the brushes are very low so this is the problem with the pump when it stops working
I have to presume the commutator should be level across its full width and if you look at the picture below the brushes have worn all the metal away and worn through to the insulation below
I must admit I have never seen a commutator worn through before, the brushes must be made of a very hard material.
Post #131207 15th Jul 2012 2:38pm
