Home > General > VentureCam
whoami
2008 Range Rover Vogue TDV8 Zermatt Silver
VentureCam
Stupid question alert Smile
Is this a standard fit piece of kit
Cheers.
Post #13063 12th Feb 2010 1:51pm
It was on certain spec models and markets.
I think it was only on th Vogue spec in the UK, and was an option on the lesser specs such as HSE and SE.
Not sure about export markets. Discovery 4 HSE
Post #13069 12th Feb 2010 2:48pm
whoami
So would it have been standard on a 2008 UK spec Vogue?
Post #13072 12th Feb 2010 3:33pm
daveo
it was available as an extra on FFRR when they had the touch screen, it was developed 2002 but had compatibility issues with the ibus system, my mate had an 04 pre touch screen with it fitted but was missing the cam when he bought it and after getting a replacement found it still didn't work.....he was told by the dealership that it is all wired in but will never work as the pre touch screen can not communicate with it. i bet some one has worked out how to get it working....
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #13078 12th Feb 2010 4:47pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
I would guesstimate standard on Bluetooth models?
My 54plate has one? 15MY SDV8 Vogue SE
Post #13093 12th Feb 2010 9:38pm
It should be standard on an 08 plate Vogue as far as I know. Mine is an 08MY 57 plate Vogue SE and has it, my previous car was an 06MY 05 reg Vogue and that had it.
That's not to say though that it was not temporarily deleted from the spec sheet and then reintroduced. This has been done with other aspects such as the Rear Seat Entertainment on the Vogue SE for example.
If you open the top glovebox does it have the venturecam charging bracket on the right hand side next to the CD changer?
if you go to the 4wd options on the centre screen is there an icon for venturecam? If so and you press it does anything happen? Discovery 4 HSE
Post #13096 12th Feb 2010 10:00pm
daveo
hi jem0911, is yours a touch screen model V8 facelift Range Rover Autobiography 22" wheels.
Post #13106 12th Feb 2010 11:20pm
Jem0911
Yes touch screen bluetooth with VentureCam.
54plate reg in Dec04.
Pre body facelift. 15MY SDV8 Vogue SE
Post #13108 12th Feb 2010 11:31pm
Paul J.
My 08 Vogue SE didn't have one.
Apparently you can not use the Venture Cam at the same time as making a phone call via Bluetooth (or so a salesman told me Rolling Eyes )
Paul
Post #13109 12th Feb 2010 11:36pm
daveo
hi yes thats right but you can use up to 16 cams at once V8 facelift Range Rover Autobiography 22" wheels.
Post #13110 12th Feb 2010 11:39pm
For an all-round Dogging cam experiencee! Rolling with laughter Discovery 4 HSE
Post #13126 13th Feb 2010 12:15pm
