|  | Home > Technical (L322) > hissing from driver side wheel arch |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | Sounds like the air bag, time to spray the soapy suds on and test for leaks | ||
|  15th Jul 2012 11:05am |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | Does hissing go away when in standard height or access height?
|  15th Jul 2012 12:26pm |
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641  | Island 4x4, Matt. Best prices on struts.
|  15th Jul 2012 4:52pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Matt, stick it up on high and gently lift the offending wheelarch up (put your backside against it and lift the wheelarch) if you get a louder hiss, its the bag... Be gentle though as your wings are alloy...
|  15th Jul 2012 6:33pm |
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737      | it wouldnt make it to high it doesnt even make it to standard height the hissing is very loud as soon as it starts to rise it past access mode
|  15th Jul 2012 8:14pm |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470      | Sounds like a bag matt.  Get some soapy water on it to prove.  Use a trolley jack to get the offending corner to raise if needed.
|  15th Jul 2012 8:40pm |
| sgtgeall Member Since: 14 Apr 2012 Location: Chichester Posts: 11      | i had the same hissing yesterday + wouldn't raise at all.. just had it recovered to the local dealer, will keep you posted. 2008 Vogue SE TDV8 Stornoway Grey, Jet Oxford Leather & Piano Black | ||
|  16th Jul 2012 6:45am |
| Posting Rules
