![]() | Home > Technical (L322) > Brakes and engine management light |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
sounds like they need bleeding again.. ... - .- -.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
As stan says...... I would run half a bottle at least through each bleed valve to make sure air was out of the system. Previously..
start at the back first V8 facelift Range Rover Autobiography 22" wheels.
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
What's the brake peddle like with the engine off?
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
The pedal is good when the car is off
Well I bled them properly tonight and they are now perfect. I think the air in the system caused the engine vacuum to be sending dodgy signals to the ecu and that was the cause of the engine management light to come on
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
Had to replace my rear calipers today too! |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
FAIL.
Bleed in this order For LEFT HAND DRIVE: Right Front Left Front Right Rear Left Rear For RIGHT HAND DRIVE: Left Front Right Front Left Rear Right Rear Jim 2000 NAS HSE 2005 NAS HSE |
You only need to bleed the part of the system that you disturbed. As in front or back, then start at passenger side. |
