![]() | Home > Technical (L322) > 2006 4.2 supercharged cut out and wont start |
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
Edited , just noticed you said it was running on LPG , no doubt one of the LPG. Guys will be along to help you |
| Alexdyer Member Since: 11 Feb 2012 Location: Bluebell hill village Posts: 24 |
Sorry it was running on LPG when it cut out!
just to add there was less than 1/4 tank of fuel in the petrol tank at the time but i was actually driving on LPG when it cut out. |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
Does the engine turn over but not fire or when you turrn the key it does |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
If you use search on the forum you can find some issues at quarter full tank with the secondary pump in the tank. The tank is "saddle" shaped and the secondary pump transfers petrol from the "offside" to the main pump side. If that pump does not work, the fuel stays in the offside. Since your pumps will be running very little due to the LPG, it may have seized up or is full of dirt. Lets be fair normally S/C fuel pumps have a very active life |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
+1 above
Hi as I was running on lpg at the time would it have just stopped? I could see that it would if it was starved of fuel as not being transferred to the other tank and then back to the engine but not whilst on LPG . I will get 40 litres of fuel and chuck that in. Should that be enough for it to get over to the other side ofthe tank?
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
as ebajema and gary say, there have been issues where having less than a quarter tank of petrol causes problems...why the lpg part stopped working is a matter for a qualified lpg service engineer to figure out, you dont want to mess about with gas ... ... - .- -.
H I have just put 40ltrs in and still no joy! Is there an emerita cut off switch in these cars? |
Did you switch to Petrol from LPG? |
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
How did you get 40 litres to a car that won't start |
I used an autoboss v30 to read the ecu
it sounds like the lpg setup is somehow stopping the petrol side from firing or the battery might just be under power.. ... - .- -.
Is it turning over on the starter or just doing nothing at all? Land Rover Addict
| All times are GMT |
