|  | Home > Maintenance & Mods (L322) > CHECK COOLANT LEVEL |
| Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746    | I think you also get this message if the antifreeze mixture is too weak. Did you top up with water or water / antifreeze mixed? | ||
|  16th Jul 2012 12:56pm |
| winslo Member Since: 12 Sep 2011 Location: Morpeth, Northumberland Posts: 135    |
 Just water! Could be my problem! | ||
|  16th Jul 2012 1:00pm |
| KARMANN Member Since: 13 Dec 2010 Location: Scotland Posts: 95    | let me know how you get on with this?
|  17th Jul 2012 11:12pm |
| winslo Member Since: 12 Sep 2011 Location: Morpeth, Northumberland Posts: 135    | I took some water out and added some anti freeze, started it up and message gone . Drove 3 miles and it came back on! So drainec a but more and topped up again when it was left overnight. Started it up and message gone. Done 100 mile and uts not come back on so fingers crossed thats it sortef!
|  17th Jul 2012 11:16pm |
| KARMANN Member Since: 13 Dec 2010 Location: Scotland Posts: 95    | good good-ill maybe try that now too.
|  17th Jul 2012 11:19pm |
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700    |
|  17th Jul 2012 11:20pm |
| Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543      | Yes, I believe it checks the specific gravity of the coolant. No longer FF owner but still interested. Present car Jaguar XE
|  17th Jul 2012 11:35pm |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470      | yep what mike said.  the sensor is in the bottom of the tank in one of the 4 chambers.  It works on a 50/50mix if there is to much water you get the check coolant bong and the same for if you put to much coolant in.  You can buy a syringe type thing from halfords that uses coluored balls to help get your mix right. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
|  18th Jul 2012 3:17am |
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641  | As Mike and Rob have said, the mixture is checked in much the same way as an external antifreeze tester through a float that is calibrated to check the specific gravity. This is to avoid someone performing a repair like Winslo, forgetting about it, and ending up with a popped block next winter.
|  18th Jul 2012 8:13am |
| Posting Rules
 That's interesting.... So there is some sort of chemical sensor that checks the level of antifreeze to water?
