![]() | Home > Maintenance & Mods (L322) > 2008 TDv8 Rear disc + Pad change Done |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Has no one changed the pads n discs on a tdv8? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
No special tools required, just slacken off the handbrake shoes adjuster before you pull off the disk otherwise you can pull the spring clips through the backplate... |
Get a copy of Bodsy's Brake Bible if you're unsure. All D3 focussed but essentially the same as a FFRR. Can be found here.
Thanks Craig |
