![]() | Home > Maintenance & Mods (L322) > TD6 Engine oil |
m90got Member Since: 18 Oct 2011 Location: scunthorpe Posts: 120 ![]() ![]() ![]() |
I would imagine this has been covered before But is any one using any differant oil other than Castrol edge 5w40 |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 745 ![]() ![]() |
Slightly off topic, but if you are using the Castrol (I did) - There's 31% off the price at Eurocarparts at the moment ..
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Halfords diesel oil fully synthetic 5w 40........
http://www.ebay.co.uk/itm/180917810348?ssP...1423.l2649
But if you include the delivery charge for 10 litres, the Castrol only works out about £2.50 more |
But you get less of it as you need at least 9 to do the td6 |
Just check the handbook and see which one would suit you best for your use |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
Ive been using Unipart FS 5w40 for some years, meets the full BMW oil spec..... its the same as Fuchs TITAN but i can get 2x5lts from my local Unipart shop for £44............and i change the oil arround the 6k mark |
I take on board the Halfrauds comment.
misteralz Member Since: 30 May 2012 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
Mobil 1 here, 5 litres from Costco is 30 quid. 4 litres of Edge is the same. Both conform to the same specs making it a no-brainer... |
I'm swinging towards Mobil 1 for my next change now.
I think it's the 5w40 Turbo Diseasel stuff I got. There's enough left over for topping up between changes if need be. 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten... |
I ended up with 20ltrs of 5w40 delivered to my door from Watsons lubricants for £67 the correct speck for my ffrr |
