Home > Off Topic > Dell Windows 7 licence keys
I bought 6 used Dell PC's with Windows 7 installed - everything worked perfectly until today when they all started saying they needed activating & that I may be the victim of counterfeit software !
I cant find any COA stickers on the units themselves, so I think I may have been conned & can't get hold of the seller - no longer registered on eBay
I've looked at buying the licences, but at ~£150 that's what I paid for the PC's in the first place
It appears to be a Dell specific install - I tried another key I have on a knackered PC, but that wasn't accepted.
Is there anywhere I can buy 6 copies of Win 7 Pro 32bit for reasonable money ?
Or get hold of Dell licence keys ?
Post #132079 19th Jul 2012 10:31pm
Budgie
Try searching for a Windows 7 OME licence.
These are normally for system builders but the licences are around £50-£80 and totally ligit. Wink
If you're buying 6 then you may be able to work out a discount as well but if there are a counterfit install then it may be worth doing a complete re-install with the new licence, to make sure everything is ok.
Post #132085 19th Jul 2012 10:56pm
Hi Ali,
I do this kind of thing day in day out and could pop over this weekend to help you out as i do a sideline in this Smile
Normal OEM stuff is a bit tricky and a PITA to get right, specially with W7/8 Smile
Drop us a line if your interested as there are a few on here and D3/4 Forum that can vouch for my services. Budget on about 10mins per machine to get the job done but when i do it, its done right Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #132087 19th Jul 2012 10:58pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
be careful there is no spyware installed.
Personally I would reformat the hard drive and install a new OS from scratch.
Do you need windows? You could try http://www.ubuntu.com/
Post #132088 19th Jul 2012 11:03pm
Looks like a 'legit' install - but with a temporary key
They came with a Dell re-installation disc & have tried re-installing with that tonight - it basically looks like it installs properly, but with a temporary licence key - you then need to activate it within 30 days which is where it now seems to be failing Big Cry
kingpleb - I'm away a lot over the next few weeks & the next 7 weekends - My family are in France for the summer, so I'm backwards & forwards - one of the PC's is now in France too !
If I can't figure it, I'll drop you a line
Post #132092 19th Jul 2012 11:22pm
No problems alistair Smile
I can do a full reinstall but take about 30-60mins a machine Sad
But can then activate and leave them to pull te updates down Smile
I use the good stuff from dell mind.
There is a bios part to the activation which may be your downfall. There are online things that may help, bust as above be aware of spyware and get MSE installed ASAP as its free and does a fairly decent av/sec job for machines Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #132094 20th Jul 2012 12:04am
A1GSS
Thumbs Up +1 for MSE. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #132105 20th Jul 2012 8:01am
Thanks kingpleb
It does indeed look like a BIOS problem - apparently I need A15 or higher for the Dell OEM to work, but the machines I have don't have a BIOS revision that new.
So it looks like I have 4 choices - live with annoying messages and without updates, use a dodgy tool to remove the BIOS check somehow, stick my hand in my pocket and donate a ridiculous sum to Microsoft or find some un-used Dell COA tags from machines that were wiped or installed with XP.
So I guess it's option 2 or 3......
Post #132230 20th Jul 2012 5:54pm
Why can't you upgrade the bios?
These should be available on the Dell site for download and installation .
Post #132238 20th Jul 2012 7:17pm
Dell don't upgrade the BIOS for older machined - the one I'm on at the moment is a GX620 & Dell only have BIOS A11 available for download. Apparently only versions A15 or later work with OEM Win 7.
I have found a site that has a modified BIOS with SLIC 2.1 on it which will apparently work.
I'm just about to take the plunge with that
Post #132310 21st Jul 2012 1:52pm
A1GSS
Is this right? I've got a 7 year old Dell D600 laptop running Windows 7 perfectly well... Graham
____
Post #132317 21st Jul 2012 2:10pm
It depends on which version of Win 7 & where you got it from.
Google has made me an expert in the last 24 hours or so Neutral
If you buy a version from Microsoft it will come with a licence key and you can install it wherever you want.
If you get a copy of the manufacturers own OEM version, then it will only install on their machines - Dell has their Windows 7 versions locked down to something hidden in the BIOS that was only added with BIOS revision A15.
They have, quite understandably, not gon back and produced A15 BIOS versions for machines that pre-date Win 7 and never shipped with it.
With a Dell re-installation disk, if you've got A15 or higher, then it just installs and works without needing a key. If your BIOS is older, it works fine in trial mode for 30 days, then tells you its not genuine.
Bit of a moral dilema for me here - I bought in good faith, but accept that the installs are not legit. However, the Microsoft pricing policy strikes me as nuts given that it's only an operating system and I've got more PC's than people in my house. I'd be OK paying a couple of hundred, but at over £100 ber box -there's no way I'm paying £600, so the end result is that I'll probably end up paying zero and feeling slightly guilty..........
Post #132319 21st Jul 2012 3:08pm
Windows Loader Whistle Thumbs Up
Post #132320 21st Jul 2012 3:17pm
mjdronfield
+1......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #132322 21st Jul 2012 3:48pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Be aware if you put a custom BIOS on you'll likely reset all the settings too, if your not sure how to customise a BIOS it can be a minefield - things like memory timings, CPU settings even voltages can (but are normally locked down) changed, apologies if you already know how to do this tho.
The easier option for most is either a boot loader that loads before the OS and cons the OS into thinking it has an branded BIOS thereby activating the install or the other option is tools that can disable the 'Windows Activation Technology' component.
Obviously I only tell you this for simple trivia, piracy is a crime and should not be condoned.
Whistle
Post #132324 21st Jul 2012 4:02pm
