Home > Off Topic - Other Cars > It doesn't just happen to FFRRs
Having put up a post singing the praises of my A4 Cabriolet, it was bound to happen Evil or Very Mad
Christmas tree lights on the dash, failsafe gearbox mode. On research this is a common fault with the multitronic (CVT) gearbox on these cars. The Gear selector lights PRNDS start flashing on and off, and you drop into a failsafe mode, which gives a big "clunk" when you go to pull away, but quite driveable after that, but you can lose Reverse.
Fault codes diagnosed as a valve solenoid issue - which equals @ £2000 for parts and labour at a main dealer, so working with my Audi indie (SJB Autotech in Basingstoke - good people) we tried first changing the gearbox oil - was due anyway. This didn't help.
Gearbox Oil has to be changed on every 40,000 miles in the service schedule - so not sealed for life Wink
Researching more on the Audi forums, and with advice from my indie next thing to try was having the gearbox ECU repaired/reconditioned. A new one of these is @ £900, reconned £300. Audi in their wisdom placed the ECU inside the gearbox where the oil goes, so I guess over time the heat and activity in there causes breaks in the silver soldering.
So back into SJB for gearbox oil drain (at least it had now had a good flush) back cover off the box and remove the ECU. Replacement back from mender in three days, and all problems solved Very Happy
General advice is to go for the tiptronic gearbox that doesn't appear to have these issues, but the multitronic appears to be just fine for me. You get gear change buttons on the steering wheel - early version of paddles, and being CVT the changes are very smooth, almost imperceptible. My Auntie had a DAF @ 30 years ago - very different beast with same idea Wink .
Post #132160 20th Jul 2012 11:25am
Shocked
change the battery tim, you know you need one.. Mr. Green ... - .- -.
Post #132162 20th Jul 2012 11:27am
That was the first job I had to do after I got the car, and just after a double hernia operation too!! .
Post #132163 20th Jul 2012 11:28am
Reformed
Im looking at getting an A5, but definately not an auto. Reformed
Post #132166 20th Jul 2012 11:31am
Aren't these Audi things just expensive Skodas ?!? Wink
Good work fella, the Citroen C2/3 sensomatic have a similar kind of issue but that does require lots of new parts and lots of fiddly time in a small engine bay Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #132175 20th Jul 2012 12:20pm
@ kingpleb
"expensive Skodas"
Yes, a bit like face-lifting the original L322 Smile .
Post #132178 20th Jul 2012 12:36pm
Sure is Smile
Though it was a quote from a friend who worked for the 4 rings at the time many moons ago Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #132181 20th Jul 2012 12:47pm
