![]() | Home > Technical (L322) > What's the difference? |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Between cons1 and cons2 in the mpg section of the OBC? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2056 ![]() ![]() ![]() |
Noddy
I take it, it's not "live" then? Our golf Shows a live display, which is constantly recalculating itself as you drive. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
You can enable instant MPG from the hidden menu on the binnacle - but it only shows it on the binnacle and is a bit of a mission.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
It's a rolling average Discovery 4 HSE
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 781 ![]() ![]() ![]() |
I reset Cons1 at every fill and leave Cons2 untouched. This way, I see what I'm getting from a tank and what I've achieved since the car was new. Cons1 is the same as I see on the LCD. There is no 'instant' MPG on a TDV8 unless you keep pressing the reset button every few seconds. |
and you can edit the computer readings you see in the binnacle by pressing the indicator stalk button and holding it until the Nav screen changes to show all the options = NB This is for the touch screen interface. Discovery 4 HSE
How is this done then? Intrigued! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
ENVOY Member Since: 25 Mar 2007 Location: up a track in the middle of nowhere Posts: 239 ![]() ![]() ![]() |
leave cons1 and cons2 untouched for long enough and they both show the same! Not a lot |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
I've noticed that, both of mine have evened out at a whopping 15.6mpg, good job it isn't a daily driver! 2006 Mercedes CLS
