![]() | Home > Maintenance & Mods (L322) > B pillar black finisher |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8001
Are the B pillars not actually the window surrounds ?
| nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233
I have the same appearance but on the vertical bit in the picture. I decided to leave it in place and rubbed it down with1200 grit wet and dry, then sprayed it with satin black. Looks perfect again! |
I'm wondering whether that might be easier with mine to be honest.
I found an example of the trim in various places - only £20 but to be honest, although the finish of the satin spray isn't as smooth as the original, it does refresh the appearance of the panel, and is a good value for money bit of maintenance. |
As the little black strip at the bottom of the window seems to be about £30 odd, I didn't even ask how much for the window surround.
| ollielloyd Member Since: 09 Oct 2012 Location: United Kingdom Posts: 120
Not done it, but I believe its screwed on from behind, ie you have to remove the door card and seal to get to the screws ........... 2011 Range Rover Vogue SE 4.4 TDV8
| All times are GMT |
