Home > Technical (L322) > turbo screech?
dave.s
turbo screech?
couple of weeks ago when leaving underground carpark got a squeeling noise for about 100 yards,didn't worry too much thought it was prob a belt slipping. this happened every few days for first week but now every time i go to and from work it squeels for first 1-200 yards. took to my local indy today and of course it woundn't squeel to order. booked in for a look tomorrow and as pulled away it squeels, mech looks at me and says sounds like turbo
will check all hoses and call me. so now can't to hear the good news. the wifes face was a picture when told.now going for a beer as could be last one.
dave
Post #132545 23rd Jul 2012 5:22pm
Budgie
It could just be a split intercooler hose, see THIS THREAD. Wink
Post #132599 23rd Jul 2012 11:00pm
dave.s
yes have read that thread and hopeing i have the same outcome,
but like to get it into my head that this might be lots of money
and be ready for it.
dave
Post #132602 24th Jul 2012 5:23am
Budgie
Sometimes it can be down to the simplest things though.
My 300 TDi Disco it started squeeling, in this case I knew it was the drive belt as I sprayed as little WD40 onto the belt while it was squeeling and it stopped.
I changed the belt but it only lasted a couple of weeks before it started again. In the end it turned out that the tensioner pulley was slightly out of line, a common fault on the 300's, and all it took to fix was a washer placed behind the tensioner body. Fixed the problem for the next 5 years. Mr. Green
By all means, prepair for the worst but always hope for the best. Thumbs Up
Post #132611 24th Jul 2012 9:07am
Not a good idea to spray rubber belts with WD40 as it can ruin the rubber. Better to spray plain water on the belt which will not cure the squeak but does let you determine where the source of the noise is coming from
Post #132636 24th Jul 2012 10:40am
When you said underground car park I first thought of tyre squeal....... .
Post #132643 24th Jul 2012 11:07am
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
[quote="47p2"]Not a good idea to spray rubber belts with WD40 as it can ruin the rubber. Better to spray plain water on the belt which will not cure the squeak but does let you know.
I agreee with the "dont use WD40 on rubber belts". Try wearing a pair of rubber gloves & spray them with WD40, they'll last about 10 seconds after that. You can use brake fluid for a longer lasting effect & as already mentioned it would rule out a belt problem one way or another.
Robert. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #132763 24th Jul 2012 10:26pm
Budgie
The belt was shiny & cracked so it didn't really matter what I sprayed on it as it was getting replaced with a Gates belt anyway. Wink
Post #132775 24th Jul 2012 11:09pm
dave.s
well still waiting to hear whats wrong had to get a lift home from work
and boss picking me up this morning as don't do buses.
dave
Post #132788 25th Jul 2012 5:21am
dave.s
picked up car today, garage can't find the cause of noise. have checked all hoses
and the turbo which seems ok. said to get second opinion as they don't want to put new turbo on if thats not whats causing the noise. spoke to Brian at Harris Mayes and taking it there in the morning see if he can
shed some light on the problem. all things crossed at the moment.
dave
Post #132899 25th Jul 2012 4:11pm
Mine has a screech on startup every now and again and i'm just putting it down to a belt covered in muck that needs cleaning off when the rest of the engine bay gets done as i've checked and nothing is amiss round there Sad Luckily if it does go prang its just PAS/AC/Alt that loses power and the engine is safe Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #132903 25th Jul 2012 4:23pm
dave.s
K.P. thats what i thought it was but going away a week saturday on a 2 week cruise and dont want to
be standing on the hard shoulder of m3/m27 on way to or from southamton so really want to get
sorted before i go.
dave
Post #132909 25th Jul 2012 4:31pm
dave.s
well the good news its not the turbo.
lucky for me its only the torque converter eating itself ,
left at garage for new gearbox etc £2800 happy days
dave
Post #133011 26th Jul 2012 11:06am
Budgie
Oooh, that's gotta smart a bit! Sad
Post #133012 26th Jul 2012 11:11am
dave.s
hi budgi, got to say wasn't what i was expecting but looking on the bright side
at least i know the turbo is okay and got them to change breather filter.also now
got the dreaded gearbox failure over with ho ho
dave
Post #133028 26th Jul 2012 11:35am
