Home > Maintenance & Mods (L322) > A and D Pillar removal ...
Checked the search button with "A and D pillar removal" nothing came up ……
Regarding the A and D pillars are these easy to come off and is there a risk of breaking any small plastic clips on them or would it just be easier to buy new fronts and rears
Post #132632 24th Jul 2012 10:19am
Ginger
2006 Range Rover Vogue 4.4 V8 Santorini Black
On the external A pillar trims, the 4 clips on the inside of the door shut are normally considered as single use.
You push the plastic pin through into the A pillar steel structure void.
The clips on the outside nearest the windscreen are a gamble so best to buy them too..
They should just pull off..
8 of each type in total..
Post #132692 24th Jul 2012 3:43pm
