Home > Maintenance & Mods (L322) > IIDTool from Gap Diagnostics
Page 12 of 15 <123 ... 1112 131415>
Patrick very kindly supplied me with a new code when I swapped cars recently.
I chose not to mention it incase it was just a "one off", but it seems not, so they're a thouroughly decent bunch of chaps!! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #132957 25th Jul 2012 10:06pm
indeed they are.. Thumbs Up ... - .- -.
Post #132974 26th Jul 2012 8:34am
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
I have just activated my IID tool. Before I start using it, how do I check the firmware version, and how should I update it. I cannot find anything on the "My GAP" tab on the website which looks like a download. Thanks in advance.
Post #133094 26th Jul 2012 4:07pm
to the left in 'my gap' you'll see 'latest releases'...click on that and download the 2.17 updater... ... - .- -.
Post #133096 26th Jul 2012 4:11pm
nubbin
Thanks Stan - that's weird - I posted the question from my computer at home, got to work and now I can see the latest updates tag - must be my home PC that's being awkward! I'll have another go later.
Post #133101 26th Jul 2012 4:27pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
It takes GAP a little while to update their database after you've completed your registration/activation. It caught me out as well.
Post #133102 26th Jul 2012 4:49pm
nubbin
Ah, thanks!
Post #133105 26th Jul 2012 5:05pm
nubbin
I've been using my IID successfully except that when I try to clear fault codes from "All ECU" the fault codes tick by but at the end it always says "Update Failed" - does this mean the faults have not cleared, and if so, what is the reason for this?
Can someone from GAP please get back to me to let me know what to do?
Post #152118 19th Nov 2012 7:34pm
daveo
hi, see on here the other day someone was looking for the hot monitoring in the menu, i to could not see it in my menu, the cold was there.. any idea's V8 facelift Range Rover Autobiography 22" wheels.
Post #152160 19th Nov 2012 11:09pm
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi Guys
"I've been using my IID successfully except that when I try to clear fault codes from "All ECU" the fault codes tick by but at the end it always says "Update Failed" - does this mean the faults have not cleared, and if so, what is the reason for this?"
The number you see is the actual number of ECU's on which faults were cleared and not how many faults were cleared. “Update Failed”: What happens is that one or more ECU's faults were not cleared. First:
-Is your IIDTool firmware up to date? (V2.17)
-Fault clearing must be done with the engine off on some ECU's. Using the clear all function with the engine running may cause this.
“see on here the other day someone was looking for the hot monitoring in the menu, i to could not see it in my menu, the cold was there.. any idea's”
It actually depends on your LCM ECU hardware version. If your ECU is the second and latest version, it will allow you to turn hot and cold monitoring ON or OFF. If it’s the first version, only the cold monitoring is configurable.
Cheers!
Post #152165 19th Nov 2012 11:53pm
daveo
well that answer my question, thanks Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #152166 19th Nov 2012 11:58pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
Hi, i have posted this on the Q&A thread also, but i thought i may aswell try here also.
I have Just bought one of these well regarded items, but im having trouble with the ccf part of it. I have a 2005 td6 facelift with the touchscreen. But when i select ccf it says ccf read fail. And im not able to save the config file either.
I have tried with the engine running ond just with the ignition on, it scans all 22 ecus ok. im not sure what is going wrong. Truth be told, this was the main reason i bought the item, so i could change the settings around.
Any help will be greatly appreciated.
Kind regards, Luke
Post #152397 20th Nov 2012 9:43pm
no need to post twice Luke, not all questions can be answered straight away.... ... - .- -.
Post #152399 20th Nov 2012 9:56pm
barracuda816
My apologies Stan.
Usually i wouldn't however i thought there may be people watching one thread and not the other.
Please feel free to delete one of the posts if i have come across impatient.
Kind regards, Luke
Post #152402 20th Nov 2012 10:06pm
the chaps from Gap only come on during the day normally so i'm sure your question will be answered tomorrow (hopefully Laughing ) ... - .- -.
Post #152404 20th Nov 2012 10:27pm
