![]() | Home > Maintenance & Mods (L322) > Plenty refrigerant but no cold aircon: EDITED - and no heat! |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
You say you can get all the fan speeds - so that means it's not the resistor. You really need to get it checked out properly. See if there are any fault codes stored anywhere. It sounds like blend motors have stopped working - which could be because the HEVAC system has faulted and shutdown. |
He's in Scotland though - it will still be calling for max heat to thaw the permafrost up there. ![]() |
I think you've no option - unless you can read the fault codes yourself you are working in the dark. Even if you fix whatever is broken, it still might not work until it's been reset. Range Rovers are like that. |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
Does it only go down to 16 degrees? After mine was re-gassed it was measured at the vents with a thermometer and goes down to 4.4 degrees 2003 Vogue 4.4 V8 Java Black |
16 degrees is the coldest you can select on the dial - that's to set the internal temp of the car to 16 - obviously the air from the vents will be colder than this, but how cold will depend a little on ambient temperature. |
Yeah I know but misteralz says that IS the temp at the vents
misteralz Member Since: 30 May 2012 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
Yeah, the temperature from the vents remained reasonably static wherever the dials were rotated to - be that 16 or 28 degrees, the temperature coming out of the vents remained around 23 degrees. |
